Вчера в 12:54
Гостей: 370
askue:
бекас, День добрый!Пробейте пожалуйста
VIN Z94CT41dbfr341091
⊙ Z94CT41DBFR341091 - 2014/08/05 (RUSSIA)
RRUSPSBR14 SOLARIS 14(RUSSIA PLANT-RUS)
ENGINE : W61G(G4FCEW561865)
T/M : TQ01(NAEWA2099435)
SEAT :
INTERIOR : RY (OCEANIDS BLACK)
EXTERIOR : RHM (SLEEK SILVER)
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 6 SPEED 2WD
ALL  AUDIO
S 0091A4 ENGINE PACKAGE - CVVT ENG
S 2531A1 RAD CORE MATERIAL - RESISTANT CACL2
S 2532B4 RAD LABEL - RUSSIA
S 2841B6 EMISSION REGULATION - EURO 4
S 2843A2 EVAP. GAS CONTROL - EURO-3
S 2911A2 UNDER COVER - W/O NOISE PAD
S 3111C7 FUEL TANK CAPACITY - 43 LITER
S 3711A8 BATTERY CAPACITY - 60AH (20HR)
S 4503A1 SHIFT LOCK SYSTEM - MECHANICAL TYPE
S 529TA7 TOOL SET & JACK LABEL - EUROPE
S 5291C3 STEEL WHEEL - 6.0J * 15
S 5293DB 185 TIRE - 185/65 R15
S 5296C1 FULL SIZE WHL COVER - A TYPE
S 5297A1 FULL SIZE 1EA - STEEL WHEEL & TIRE
S 5411A1 FR SUSP TYPE - MACPH. W/COIL SPRING
S 5412A1 S/ABSORBER TYPE - OIL
S 5511A9 RR SUSP TYPE - TORSION AXLE
S 5512A1 S/ABSORBER TYPE - OIL
S 569BE1 AIR BAG LABEL(PASS S) - PICTOGRAM
S 5691A3 DRIVER SIDE - DEPOWERED
S 5692A3 PASSENGER SIDE - DEPOWERED
S 5711A2 HPS(HYDRAULIC POWER STRG)
S 5811A3 FR BRAKE - DISC-14 INCH
S 5812A7 RR BRAKE - DISC-14 INCH
S 5891A2 ABS (ANTI LOCK BRK SYS)
S 5896A1 ESS (EMERGENCY STOP SIGNAL)
S 5911A2 SINGLE BOOSTER - 9 INCH
S 5972A1 P/BRAKE KNOB TRIM - SOFT PVC
S 6501A1 HIGH GRADE
S 811AA1 HOOD INSULATOR
S 8123A2 TRUNK LID RELEASE TYPE - CABLE
S 8124A1 TRUNK LID TRIM - FULL COVER
S 8131A1 CENTRAL DR LOCK/UNLOCK - DR S CONTROL
S 8136A1 CHILD SAFETY RR DR LOCK G
S 8152A3 FUEL FILLER DR REL TYPE - CABLE
S 8191A2 KEY TYPE - INSIDE CUTTING
S 82A5A1 MAP POCKET-FR DR
S 82A7A1 MAP POCKET-RR DR
S 822AA1 DR BLACK OUT MATERIAL - TAPE
S 8236A7 ARM REST COVER G - PLASTIC
S 8237A1 ARM REST HANDLE - PULL TYPE
S 8241A2 FR DR GLASS - TINTED
S 8245A2 RR DR GLASS - TINTED
S 8262A3 LEVER FINISH G - METAL PAINT
S 834AA1 AUTO DOWN
S 8349A1 SW ILLUMINATION(ALL)
S 8421D3 N/PUNCH - HIGH VELOUR TYPE
S 8441A5 FR - PORTABLE
S 8445A1 CIGAR LIGHTER - W/O ILLUM.
S 8451A1 W/O LOCK
S 846CA1 CONSOLE TRAY - W/O FLOCK G
S 846EA1 POWER OUTLET
S 8461A1 STD
S 8462A1 CUP HOLDER - FR(W/O ILL)
S 8481A6 GRAIN - METAL PAINT
S 8511B1 DAY/NIGHT TYPE
S 852GA1 VANITY MIRROR - GLASS TYPE
S 852HA1 VANITY MIRROR COVER
S 8521A1 MATERIAL - VINYL
S 8522A1 VANITY MIRROR - GLASS TYPE
S 8523A1 MATERIAL - VINYL
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8531A2 ROOF TRIM MATERIAL - FABRIC
S 8532A1 FR - 1 EA
S 8561A1 RR P/TRAY MATERIAL - PLASTIC
S 857KA1 LUGGAGE UNDER TRAY
S 8571C1 LUGGAGE SIDE - W/PAPER
S 8573A2 FLOOR - WALL PAPER
S 8612A1 MLD G-WINDSHIELD - BLACK
S 863AAP CAR NAME - SOLARIS
S 863CA1 GRADE - GL
S 8631A6 A TYPE - BLACK+CR COAT G
S 8641A1 TOWING HOOK
S 8642A1 TIE DOWN HOOK(LASHING)
S 8643A1 SHIPPING HOOK
S 8651B1 TYPE - 2.5 MILE
S 8652B1 COLOR - BODY COLOR
S 8681A1 MUD GUARD-FR
S 8682A1 MUD GUARD-RR
S 871BA1 RR HEATED W/ TIMER
S 8712B4 BACK LITE GLASS TYPE -TINTED(W/ HEATED)
S 8722A3 H.M.S.L - RR P/TRAY
S 8731B1 MLD G - BODY COLOR
S 8811C1 CLOTH - CLOTH
S 8821A1 HEAD REST - UP/DOWN
S 8823A1 SLIDING
S 8824A2 DOUBLE RECLIN G
S 8825A4 ADJUSTER - PUMP G DEVICE
S 885DA1 SLIDING
S 885EA2 DOUBLE RECLIN G
S 8854A1 HEAD REST - UP/DOWN
S 886BA1 SEAT BACK - SEAT BACK POCKET
S 888AA2 PRE TENSIONER - ELECTRICAL TYPE
S 888DA1 SEAT BELT REMINDER
S 888KA2 S/BELT ANCHOR - ADJUSTABLE
S 888RA2 S/BELT ANCHOR - ADJUSTABLE
S 8881B1 DRIVER S SIDE - ELR
S 8884D1 PASSENGER S SIDE - ELR
S 8885A2 RETRACTOR PRETENSIONER - ELECTRICAL TYPE
S 8913A1 LH
S 8914A1 RH
S 892DA1 HOLDER - UPR ANCHOR
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 921BA1 LEVELING DEVICE - MANUAL
S 9211E3 MFR - CLEAR
S 9213A3 DRL - DEDICATED BULB TYPE
S 9222A1 RR - CONVENTIONAL
S 923DA1 ONE TOUCH TRIPLE TURN SIGNAL
S 9231B1 INTEGRATED - CLEAR LENS
S 9232A1 CONVENTIONAL - CLEAR LENS (ON FENDER)
S 9241A1 RR COMBI LAMP - CLEAR
S 928FA1 CTR - GLOW LAMP
S 928WA1 BULB TYPE - 1 BULB
S 9287A1 LUGGAGE LAMP
S 94C1A1 A/T POSITION INDICATOR
S 94C6A1 DIRECTION INDICATOR
S 94C7A1 OIL PRESSURE
S 94C8A1 BRAKE OIL
S 94C9A1 PARK G BRAKE
S 94D0A1 DR AJAR - DR AJAR
S 94D1A1 BATTERY CHARGE
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94D7A1 TRUNK LID(T/GATE) OPEN
S 94D9A1 CHECK ENGINE
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 94F1A1 A/T OD'POSITION INDICATOR
S 94G0A1 LOW WASHER FLUID
S 94G4A1 FR FOG LAMP
S 94H6A1 IMMOBILIZER
S 94M0A1 SPEEDOMETER TYPE - KMPH
S 94N0A1 TEMPERATURE UNIT - C
S 94X2A1 ECO INDICATOR
S 940AA3 TRIP ODOMETER - LCD
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 940DA1 WATER TEMP.
S 940EA1 LCD ODO/TRIP METER
S 9401C1 CLUSTER TYPE - CONVENTIONAL
S 9402A1 SPEEDOMETER
S 9451A1 TYPE - DIGITAL
S 9542A1 IMMOBILIZER
S 9621K1 ANTENNA TELESCOPIC - ANTENNA MICRO
S 963CA1 SPEAKER LOCATION FR DR - GENERAL
S 963ZA1 SPEAKER LOCATION RR DR LOW-GENERAL
S 965QA1 O/SIDE TEMPERATURE DISPLAY
S 9661A1 SINGLE HORN
S 9711A2 BLOWER - 4 SPEED FAN
S 9721A2 CABLE TYPE - ROTARY TYPE
S 9741A1 RR HEATING DUCTS - 2ND SEAT
S 9761A1 FR COOLER - MANUAL A/CON
S 981AA1 FR WIPER-2 SPEED
S 9811A2 FR WIPER - INTERMITTENT(VARIABLE)
S 9819A1 BLADE TYPE - CONVENTIONAL
S 9852A1 FUNCTION - WASHER FLUID LEVEL SENSOR
O 371CA1 BATTERY SAVER
O 4371B3 AT KNOB - LEATHER WRAPPED
O 561AA1 W/ HEATED
O 5611B3 3-SPOKE - LEATHER
O 5631A4 STEER G COLUMN-MANUAL TILT & TELESCOPIC
O 819CA1 KEYLESS ENTRY-T/OPEN
O 8194B3 TYPE - FOLDING
O 8233B1 CENTER TRIM - CLOTH(A TYPE)
O 8261A2 FINISH G - BODY COLOR
O 834CA3 SAFETY WINDOW - FR DR(DRIVER S)
O 8341A2 POWER WINDOW(FR+RR)
O 8346A1 TIME LAG POWER WINDOW
O 846BA1 W/ STORAGE BOX ARM REST - STD(1 DIN)
O 846LA1 CONSOLE COVER - CLOTH
O 8611H3 W/S GLASS TYPE-HEATED WIRE-TINTED(W/O S/
O 8762C4 PASS S SIDE - ELECTRIC HTD-CONV
O 8763C4 DRIVER S SIDE - ELECTRIC HTD-CONV
O 8765A2 COLOR - BODY COLOR
O 8838A1 SEAT WARMER(HEATER)
O 8873A1 SEAT WARMER
O 8912D1 6:4 SPLIT BACK FOLD G - BACK
O 9282A1 FR - W/ SUNGLASSES
O 9541A1 BODY CONTROL MODULE - BCM(ETACS)
O 9571A3 RR PARK G ASSIST SYSTEM(RPAS)
O 9611NK RADIO+CD+MP3+RDS - PA30A R
O 9614B1 COMPONENT- 2 DIN
O 9618A1 USB+AUX
O 967AA1 AUDIO REMO.
Вадим:
Бекас, можно узнать информацию по авто?
Hyundai Solaris седан 1.6
VIN: Z94CT41DBDR259629
Запросто :)
⊙ Z94CT41DBDR259629 - 2013/10/17 (RUSSIA)
RRUSPSBR11 SOLARIS 11(RUSSIA PLANT-RUS)
ENGINE : W24G(G4FCDW639084)
T/M : UT88(AD15U3256905)
SEAT :
EXTERIOR : MZH (PHANTOM BLACK)
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 4 SPEED 2WD
ALL  AUDIO
S 3731A2 AMS - W/ MICOM
S 4371B1 AT KNOB - SOFT PVC
S 5611B2 3-SPOKE - POLY URETHANE
S 5631A3 STEER G COLUMN-MANUAL LWR TILT
S 6501A1 HIGH GRADE
S 8236A1 ARM REST COVER G - PVC
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 8611B2 W/S GLASS TYPE-TINTED (W/ S/BAND)
S 863CA1 GRADE - GL
S 8631A5 A TYPE - BODY COLOR+CR COAT G
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 9213A2 DRL - EUROPE TYPE
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9621G1 ANTENNA TELESCOPIC - ANTENNA ROOF TYPE
O 0101B1 MODEL YEAR PACKAGE - 13MY
O 569BD4 PASS S - D LANGUAGE
O 5692A3 PASSENGER SIDE - DEPOWERED
O 5812A7 RR BRAKE - DISC-14 INCH
O 5891A2 ABS (ANTI LOCK BRK SYS)
O 5896A1 ESS (EMERGENCY STOP SIGNAL)
O 86A1A1 W/ WIPER DEICER
O 9221A2 CONVENTIONAL - CLEAR LENS
O 9611NG RADIO+CD+MP3+RDS - PA 710R
O 9618A1 USB+AUX
O 963KA1 SPEAKER LOCATION TWEETER-FR DR UPR
O 9761A1 FR COOLER - MANUAL A/CON
кисловодск
Добрый вечер Бекас.Пожалуйста пробейте VIN Z94CU41DABR064807 Большое спасибо.
akyla:
⊙ Z94CU41DABR064807 - 2011/09/28 (RUSSIA)
ENGINE : W22G(G4FCBW343587)
T/M : ZG83(TBJ5 D756728)
SEAT :
EXTERIOR : VEA (ICE SILVER)
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
MANUAL T/M - 5 SPEED 2WD
ALL  AUDIO
S 371CA1 BATTERY SAVER
S 4161A2 CLUTCH TYPE - HYDRAULIC
S 4501A1 CLUTCH LOCK
S 569BD4 PASS S - D LANGUAGE
S 5973A3 P/BRAKE PUSH BUTTON TRIM - CR COAT G
S 6501A1 HIGH GRADE
S 813BA1 IMPACT SENS G AUTO DR UNLOCKG
S 813DA1 IGN KEY REMINDER
S 8233B1 CENTER TRIM - CLOTH(A TYPE)
S 8261A2 FINISH G - BODY COLOR
S 8262A2 LEVER FINISH G - CR COAT'G
S 834AA1 AUTO DOWN
S 8341A2 POWER WINDOW(FR+RR)
S 8346A1 TIME LAG POWER WINDOW
S 84FDA1 CTR AIR VENT
S 8451A1 W/O LOCK
S 846BA1 W/ STORAGE BOX ARM REST - STD(1 DIN)
S 846LA1 CONSOLE COVER - CLOTH
S 8461A1 STD
S 8481B6 GRAIN - HIGH GLOSSY
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 86A1A1 W/ WIPER DEICER
S 863CA2 GRADE - GLS
S 8762C4 PASS S SIDE - ELECTRIC HTD-CONV
S 8763C4 DRIVER S SIDE - ELECTRIC HTD-CONV
S 8765A2 COLOR - BODY COLOR
S 8823A1 SLIDING
S 8838A1 SEAT WARMER(HEATER)
S 885DA1 SLIDING
S 8873A1 SEAT WARMER
S 8912D1 6:4 SPLIT BACK FOLD G - BACK
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 9221A2 CONVENTIONAL - CLEAR LENS
S 928KA1 DELAY OUT INTERIOR LAMP
S 9282A1 FR - W/ SUNGLASSES
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 94X6A1 M/T SHIFT INDICATOR
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9541A1 BODY CONTROL MODULE - BCM(ETACS)
S 9611NG RADIO+CD+MP3+RDS - PA 710R
S 9614B1 COMPONENT- 2 DIN
S 9618A1 USB+AUX
S 963KA1 SPEAKER LOCATION TWEETER-FR DR UPR
S 967AA1 AUDIO REMO.
S 9819A2 BLADE TYPE - AERO
O 4371A3 MT KNOB - LEATHER WRAPPED
O 5291KA AL WHEEL 6.0J * 16 - A TYPE
O 5293ET 195 TIRE - 195/55 R16
O 5297A3 FULL SIZE 1EA - AL WHEEL & TIRE
O 5693A1 SIDE AIR BAG-FR - FR(THORAX)
O 5695A1 CURTAIN A/BAG
O 5894A1 ESC (ELECTRONIC STABILITY CONTROL)
O 813AA1 SPEED SENS G AUTO DR LOCK
O 819HA1 SMART KEY-FR DR
O 8196A2 BUTTON START - BUTTON W/ ILLUMINATED
O 8198A3 STEER G LOCK TYPE - ESCL
O 8731C1 MLD G - CR COAT'G
O 876NA1 SIDE REPEATER LAMP (O/S MRR)
O 9401B1 CLUSTER TYPE - SUPER VISION
O 9491A1 RHEOSTAT
O 9552A2 BLUE TOOTH (AUDIO)-W/ VOICE RECOGNITION
O 967DA1 H/FREE REMO
O 9761A3 FR COOLER - FULL AUTO A/CON
Помогите пробить Z94CT51DADR100242. Спасибо. Если можно с переводом.
vvv:
⊙ Z94CT51DADR100242 - 2014/04/07 (RUSSIA)
ENGINE : W18G(G4FCDW766582)
T/M : ZG83(TEJ5 D632338)
SEAT :
SEDAN - 5DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
ALL  AUDIO
S 4371A1 MT KNOB - SOFT PVC
S 6501A1 HIGH GRADE
S 817AB3 TAIL GATE FINISH G-FORMED TYPE(PLASTIC)
S 8176A1 TAIL GATE O/SIDE HANDLE - NATURAL COLOR
S 8177A1 CENTRAL T/GATE LOCK/UNLOCK
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 8571B1 LUGGAGE SIDE - PLASTIC
S 8591B1 COVER G SHELF TRIM - WALL PAPER
S 863CA1 GRADE - GL
S 8722A4 H.M.S.L - T/GATE OTR
S 8791B1 RR QTR GLASS TYPE -TINTED
S 8792A1 CONTROL - FIXED
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9872A1 RR WIPER SYSTEM - 1 SPEED
O 9618A1 USB+AUX
Спасибо большое, а русского перевода нет. Я пожилой человек и английский не изучал, а машинный перевод -это абракадабра какая-то.Спасибо.
Или хотя бы перечень номеров строк с переводом.
vvv:
Русского нет. Специалистами по запчастям русский язык в каталогах не используется, хотя зачастую и присутствует, потому что получается криво.
Обоснуйте, зачем вам нужен этот перевод или что конкретно вы получите увидев расшифровку списка в общем-то банальных опций и я возможно найду время все это перевести. Вариант "просто интересно" - не годится.
Выглядеть это будет примерно так (вариант для Hyundai Grand Starex)Какую полезную информацию подчерпнет из этого обычный пользователь?
0FL1 F/LIFT MODEL(1'ST) - 1-я версия фейслифтинга
0MY1 M/YEAR MODEL(1'ST) - 1-я версия фейслифтинга
0950 DIESEL - это понятно
2813 AIR INTAKE-MHI(WATER TYPE) - что-то про воздухозаборник?
283C EMISSION(DOM 2002) - а/м для внутреннего рынка
3312 FUEL INJ-ELECTRIC TYPE - управление подачей топлива
371B BATTERY-90AH(MF) - аккумулятор
4372 LEATHER(A/T) - кожаная отделка ручки АКПП
528G 205/70R15 - размерность шин
530T 15"(STL) - размерность и тип колёс (сталь, штамповка)
531F FULL WHEEL CAP - колпаки на колёсах(?)
5462 GAS
5464 GAS SHOCK ABSORBER-RR - сзади газонаполненные аммо
5613 STRG-NORMAL POWER - гидроусилитель рулевого
5615 LEATHER - кожаная отделка рулевого колеса
5691 A/BAG(D/S) - подушка безопасности (со стороны водителя)
5831 DRUM - задние тормоза барабанные
6502 LOW GRADE - антикор (совсем чуть-чуть)
8133 ANTI THEFT SYSTEM-IGNITION KEY - противоугонное устройство (на руле, от ключа зажигания)
8134 CHILD SAFETY LOCK - детский замок (блокировка сдвижной двери)
8135 SPEED SEN. AUTO D/LOCK - автоблокировка замков дверей при скорости
8170 TAIL GATE TRIM-WDW TRIM - остеклённая дверь задка
8171 TAIL GATE-LIFT TYPE - дверь задка подъёмная
8191 ILLUMINATED IGNITION - подсветка замка зажигания
8195 KEYLESS(304/447MHZ) - центральный замок с ДУ
823A POCKET-DR MAP(DLX) - карманы на пер. дверях
823L TRIM-SLID'G DR(PVC) - что-то про отделку сдвижной двери
8230 TRIM-SIDE(WDW TYPE) - остекление по кругу
8236 POCKET-DOOR MAP(COVER'G) - ещё карман, закрывающийся (где это?)
8241 TNTD - тонировка
8342 WINDOW-POWER(FRT) - стеклоподъёмники (спереди)
8421 COVERG-FLR(NEEDLE PUNCH TYPE) - покрытие пола перфорированное (возможно, шумоизоляция)
8431 CAR MAT-A TYPE - не знаю
8477 WOOD GRAIN - отделка под дерево (торпеда и двери)
8479 DRINK HOLDER - напиткодержатель
8512 MIRROR-I/S(DAY & NIGHT) - зеркало заднего вида (ночь/день)
8529 SUNVISOR-DUAL(NON WOVEN) - солнцезащитные козырьки (обивка - нетканая)
858A TRIM-SIDE(PVC) - боковые молдинги ПВХ
8614 GLASS-W/S WITH HTD - подогрев ветрового стекла
8623 GLASS-W/SHILD S/BAND - полоса на ветровом стекле (от солнца)
8633 RAD. GRILLE-C TYPE - тип решётки (облицовки) радиатора
864C MUD GUARD-RR(W/O LETTER) - задние брызговики (без надписи)
8647 MUD GUARD-FRT(W/O LETTER) - передние брызговики (без надписи)
8652 BUMPER-2.5 MILE - какой-то хитрый бампер  :D
8672 ROOF RACK - релинги на крыше
8712 TNTD & HTD - тонировка и подогрев (стекла двери задка?)
8718 HEATED - подогрев (стекла двери задка?)
8722 SPOILER-LOWER(W/HMSL) - спойлер сзади (?)
8741 MRR-RR UNDER VIEW - парковочное зеркало на двери задка
875D MRR-PA'S ELEC:HTR CONV - зеркало пассажира с подогревом
8761 MRR-DR'S ELEC:HTD CONV - зеркала водителя с подогревом
879B TINTED - ещё тонировка
8801 CLOTH - обивка салона - ткань
881E SEAT-FR(WITH HEATED) PASSENGER - сиденье с подогревом пассажирское (спереди)
8810 SEAT-FR(WITH HEATED) - сиденье с подогревом водительское
8811 LUMBAR - подпор поясницы с регулировкой (вод. сид.)
8819 UNDER TRAY(P/S) - защита картера (?)
888B S/BELT-DR'S ADJUST - регулировка ремней водителя (по высоте)
888H SEAT BELT-FR DR'S P/T ELECT TY - что-то про ремень водителя
8888 SEAT BELT-FR DR'S(ELR 3PT) - ремень водителя 3х точечный
8916 3RD 5:5 SPLIT FOLD'G - 3й ряд сидений разделён пополам, складной
8981 SEAT BELT-RR SIDE(STATIC 2PT) - боковые ремни в салоне, 2х точечный
8986 SEAT BELT-RR SIDE(ELR 2PT) - боковые ремни в салоне, 2х точечный
8989 SEAT BELT-RR CTR(STATIC 2PT) - центральные ремни в салоне, 2х точечный
9215 BULB-12V P43T(H4 HALOGEN) - тип лампы головного света
9231 REPEATER-SIDE - повторители поворота (на крыльях)
9241 LAMP-FOG(FR) - ПТФ спереди
9283 LAMP-FLOURESCENT - освещение салона (люминисц. лампы)
9285 LAMP-MAP - светильник водителя и пассажира
9403 KMH
9415 TACHOMETER - тахо
9451 CLOCK-AUTO(DIGITAL) - часы
9495 RHEOSTAT - регулировка яркости подсветки приборов
9510 AUTO LIGHT - автовключение ближнего света
9542 IMMOBILIZER - иммо
9585 SHIFT LOCK-A/T - про управление АКПП
96HK RADIO+CASS(H 240) - модель магнитолы
96SA SPKR-FR DR - передние динамики в дверях
96SD SPKR-RR SIDE(COAXIAL) - задние динамики (двух- или трёхполосные)
96S5 SPKR-C/PAD - вч динамики (пищалки) на торпеде
9607 ANTENNA-GLASS(RADIO) - антенна внутрисалонная (на стекле)
9612 AM9K/FM100K - параметры приёмника (европа)
9663 HORN-DOUBLE - звуковой сигнал (двухтоновый)
970A TEMPERATURE UNIT 'C' - передняя печка
971A AUXILIARY HEATER-PTC -
972B RR HTR CONTROL(ROTARY TYPE) - ручки регулировки задней печки вращ. типа
9721 HEATER-RR UNIT - задняя печка
9727 PUSH BTN TYPE
9862 CHIME BELL - звуковой сигнал откр. двери, ремня, ручника (колокольчик)
9880 WIPER-RR - стеклоочиститель двери задка
W30THE TEMPERATE ZONE - Также, на этом а/м:
G02B A1(WGN SHORT 9) - короткий, 9 мест
G021 A1(WGN) - вагонная компоновка
2867 MFFLR TAIL PIPE TRIM-CR - сзади есть что-то хромированное)))
5003 L.D(LOCK'G DEFERENTIAL) - дифф повышенного трения
529E 15"(AL) - диски легкосплавные 15"
5614 STRG-TILT - регулировка руля
5832 DISC - тормоза дисковые (сзади?)
5891 ABS - АБС
842A COVERG-FLR(MONOLEUM) - покрытие пола линолеум
8473 MULTI BOX - мультибокс
8525 MRR-VANITY(GLASS) - самозатемняющееся зеркало заднего вида(?)
865B BUMPER GUARD 'B' TYPE - кенгуру - тип защиты бампера
877F GARNISH
8781 MLDG-ROCKER PNL - что-то с молдингами
9261 L/COURTESY - деликатная подсветка салона
9551 HANDS FREE KIT - хэндсфри (вряд ли получится подключить)
957A BACK WARNING SYSTEM - парктроник
96C3 COMPONENT-2 DIN - магнитола 2дин
96HS RADIO+CASS+CD+EQ(H 280) - модель магнитолы
9713 AIR FILTER - фильтр салона
976A S.A.T.C
979A AIR CON-SEMI AUTO(RR) - кондицинер задний полуавтомат
A99 DOMESTIC(KOREA,SOUTH) - сделано для внутреннего рынка
Спасибо мне это достаточно. Просто я покупаю хечбек, а ТОЧНУЮ комплектацию не знаю, только по проспектам.
Дайте, пожалуйста, по vin информацию о моем авто по комплектации и запчастям, ну и всему остальному) Заранее благодарю..
Z94CT41DBBR095410
Еще раз прошу пробить по vin комплектацию и запчасти. Очень срочно надо. Купил авто, теперь хочу знать все об этой машинке)
zaur624:
Прям вот срочно? :)
Многие знания - многие печали.
Интересно, что полезного для неискушенного можно подчерпнуть из нижеследующего?
⊙ Z94CT41DBBR095410 - 2011/12/28 (RUSSIA)
ENGINE : W25G(G4FCBW418074)
T/M : UT36(AB1DU013139)
SEAT :
EXTERIOR : PGU (CRYSTAL WHITE)
LEFT HAND DRIVE
WEATHER - THE FRIGID ZONE
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 4 SPEED 2WD
ALL  AUDIO
S 6501A1 HIGH GRADE
S 8261A1 FINISH G - BLACK COLOR
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8765A1 COLOR - BLACK
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 9282A2 FR - W/0 SUNGLASS
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
O 9618A1 USB+AUX
Z94CU41DBFR343826 если не трудно
Dimka:
⊙ Z94CU41DBFR343826 - 2014/08/14 (RUSSIA)
ENGINE : W61G(G4FCEW569953)
T/M : TQ01(NAEWA2118298)
SEAT :
LEFT HAND DRIVE
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 6 SPEED 2WD
ALL  AUDIO
S 4371B3 AT KNOB - LEATHER WRAPPED
S 561AA1 W/ HEATED
S 5611B3 3-SPOKE - LEATHER
S 5631A4 STEER G COLUMN-MANUAL TILT & TELESCOPIC
S 6501A1 HIGH GRADE
S 819CA1 KEYLESS ENTRY-T/OPEN
S 8194B3 TYPE - FOLDING
S 8236A3 ARM REST COVER G - ARTIFICIAL LEATHER
S 834AA1 AUTO DOWN
S 834CA3 SAFETY WINDOW - FR DR(DRIVER S)
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 8731C1 MLD G - CR COAT'G
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9401B1 CLUSTER TYPE - SUPER VISION
S 9491A1 RHEOSTAT
S 9552A2 BLUE TOOTH (AUDIO)-W/ VOICE RECOGNITION
S 9571A3 RR PARK G ASSIST SYSTEM(RPAS)
S 9611NK RADIO+CD+MP3+RDS - PA30A R
S 9618A1 USB+AUX
S 967EA1 BLUE TOOTH REMO
S 967FA1 VOICE RECOGNITION SYSTEM REMO
S 9761A3 FR COOLER - FULL AUTO A/CON
O 813BA1 IMPACT SENS G AUTO DR UNLOCKG
O 813DA1 IGN KEY REMINDER
O 921JA1 ESCORT
O 9211F5 PROJECTION - BI-FUNCTION(HIGH/LOW)
O 9213A4 DRL - DEDICATED LED TYPE
O 9241A3 RR COMBI LAMP - LED TYPE
O 9511A1 AUTO LIGHT CONTROL SYSTEM - 1 STAGE
Будьте добры Z94CT51DAFR109147
Agr1ck:
⊙ Z94CT51DAFR109147 - 2014/08/18 (RUSSIA)
ENGINE : W51G(G4FCEW559202)
T/M : ZG87(ZG87EJ346063)
SEAT : 72KD
LEFT HAND DRIVE
SEDAN - 5DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
MANUAL T/M - 6 SPEED 2WD
ALL  AUDIO
S 6501A1 HIGH GRADE
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
O 9618A1 USB+AUX
Елабуга
Пожалуйста пробейте VIN Z94CT41DADR308378. В ПТС указана дата выпуска 09 апреля 2014-го года, хотя по буквам, вроде, 2013-ый год. Спасибо!
andrey907:
Это наверное ПТС выдан 9 апреля :)Насколько я знаю в ПТС вообще дату изготовления не пишут
⊙ Z94CT41DADR308378 - 2014/04/02 (RUSSIA)
ENGINE : W18G(G4FCDW769902)
T/M : ZG83(TEJ5 D631105)
SEAT :
LEFT HAND DRIVE
SEDAN - 4DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
ALL  AUDIO
S 6501A1 HIGH GRADE
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9611A2 BLANK G COVER - GERMANY TYPE
S 9614A2 COMPONENT 1 DIN - W/ TRAY
Елабуга
Спасибо! Как приятно, что есть отзывчивые люди!
Здравствуйте, можно посмотреть vin Z94CU51CABR018780 hyundai solaris 1.4 хэтчбэк МТ, синий?
Редактировалось: 1 раз (Последний: 25 октября 2014 в 21:24)
Павел:
⊙ Z94CU51CABR018780 - 2011/11/01 (RUSSIA)
ENGINE : W11G(G4FABW377758)
T/M : ZG81(TBJ5 D799256)
SEAT :
EXTERIOR : WGM (SAPPHIRE BLUE)
LEFT HAND DRIVE
SEDAN - 5DR 5P
1400 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
ALL  AUDIO
S 6501A1 HIGH GRADE
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
S 9618A1 USB+AUX
O 8721B1 RR SPOILER W/ HMSL - A TYPE
Здравствуйте, можно посмотреть vin Z94CT51DBFR112608?
Спасибо.
SergK:
Спасибо.
⊙ Z94CT51DBFR112608 - 2014/09/25 (RUSSIA)
ENGINE : W61G(G4FCEW595360)
T/M : TQ01(NAEWA2185155)
SEAT :
EXTERIOR : M2B (MISTY BEIGE)
LEFT HAND DRIVE
SEDAN - 5DR 5P
1600 CC - GAMMA
DOHC - MPI
GASOLINE - UNLEADED
AUTO - 6 SPEED 2WD
ALL  AUDIO
S 6501A1 HIGH GRADE
S 834AA1 AUTO DOWN
S 8451A1 W/O LOCK
S 8461A1 STD
S 853AA2 RR - 2 EA
S 853JA2 RR - 2 EA
S 8532A1 FR - 1 EA
S 863CA1 GRADE - GL
S 8823A1 SLIDING
S 885DA1 SLIDING
S 8913A1 LH
S 8914A1 RH
S 892GA1 LWR ANCHOR
S 8981A4 SIDE - ELR
S 8982A4 CTR - ELR
S 94C8A1 BRAKE OIL
S 94D2A1 HIGH BEAM
S 94D4A1 LOW FUEL
S 94E3A1 SEAT BELT
S 94E5A1 A.B.S
S 94E6A1 A/BAG
S 940BA1 TACHOMETER
S 940CA1 FUEL
O 9618A1 USB+AUX
Доброе утречко,мой посмотрите пожалуйста.
Z94СT41DBDR232151
