Вчера в 12:54
Гостей: 257
Спасибо за ДР авто!Можно полную расшифровку VIN Z94CT41CABR058013?
ts-v-et:
Пробейте мой VIN : Z94CT41DBBR087580!Плиииз
Shadowru:
ts-v-et:
Спасибо!
nika9969:
Shadowru:
nika9969:
[spoiler="Информация"]Z94CT41DBBR087580
SOLARIS RUSSIA 2011/12/07
Model No DRS4D261B
Engine No G4FCBW409016
T/M No AB1DU990129U
Exterior Color 1   PGU
Exterior Color 2   PGU
Body SEDAN-4DR(5)
Engine Capacity 1.6L-GAMMA
Interior Color   RY
Fuel GASOLINE-UNLEADED
T/M 4AT2WD
0091A4 ENGINE PACKAGE - CVVT ENG
2531A1 RAD CORE MATERIAL - RESISTANT CACL2
2532B4 RAD LABEL - RUSSIA
2841B6 EMISSION REGULATION - EURO 4
2843A2 EVAP. GAS CONTROL - EURO-3
2911A2 UNDER COVER - W/O NOISE PAD
3111C7 FUEL TANK - CAPACITY - 43 LITER
3711A8 BATTERY CAPACITY - 48AH (5HR)
4371B1 AT KNOB - SOFT PVC
4503A1 SHIFT LOCK SYSTEM - MECHANICAL TYPE
5291C3 STEEL WHEEL - 6.0J * 15
5293DB 185 TIRE - 185/65 R15
5296C1 FULL SIZE WHL COVER - A TYPE
5297A1 FULL SIZE 1EA - STEEL WHEEL & TIRE
529TA7 TOOL SET & JACK LABEL - EUROPE
5411A1 FR SUSP TYPE - MACPH. W/COIL SPRING
5412A1 S/ABSORBER TYPE - OIL
5511A9 RR SUSP TYPE - TORSION AXLE
5512A1 S/ABSORBER TYPE - OIL
5611B2 3-SPOKE - POLY URETHANE
5631A3 STEER`G COLUMN-MANUAL LWR TILT
5691A3 DRIVER SIDE - DEPOWERED
5711A2 HPS(HYDRAULIC POWER STRG)
5811A3 FR BRAKE - DISC-14 INCH
5911A2 SINGLE BOOSTER - 9 INCH
5972A1 P/BRAKE KNOB TRIM - SOFT PVC
6501A1 HIGH GRADE
8123A2 TRUNK LID RELEASE TYPE - CABLE
8131A1 CENTRAL DR LOCK/UNLOCK - DR`S CONTROL
8136A1 CHILD SAFETY RR DR LOCK`G
8152A3 FUEL FILLER DR REL TYPE - CABLE
8191A2 KEY TYPE - INSIDE CUTTING
822AA1 DR BLACK OUT MATERIAL - TAPE
8236A1 ARM REST COVER`G - PVC
8237A1 ARM REST HANDLE - PULL TYPE
8241A2 FR DR GLASS - TINTED
8245A2 RR DR GLASS - TINTED
8261A1 FINISH`G - BLACK COLOR
8262A3 LEVER FINISH`G - METAL PAINT
82A5A1 ***
834AA1 AUTO DOWN
8421D3 N/PUNCH - HIGH VELOUR TYPE
8441A5 FR - PORTABLE
8445A1 CIGAR LIGHTER - W/O ILLUM.
8451A1 W/O LOCK
8461A1 STD
8462A1 CUP HOLDER - FR(W/O ILL)
846CA1 CONSOLE TRAY - W/O FLOCK`G
846EA1 POWER OUTLET
8481A6 GRAIN - METAL PAINT
8511B1 DAY/NIGHT TYPE
8521A1 MATERIAL - VINYL
8522A1 VANITY MIRROR - GLASS TYPE
8523A1 MATERIAL - VINYL
852GA1 VANITY MIRROR - GLASS TYPE
8531A2 ROOF TRIM MATERIAL - FABRIC
8532A1 FR - 1 EA
853AA2 RR - 2 EA
853JA2 RR - 2 EA
8561A1 RR P/TRAY MATERIAL - PLASTIC
8571C1 LUGGAGE SIDE - W/PAPER
8573A2 FLOOR - WALL PAPER
857KA1 LUGGAGE UNDER TRAY
8611B2 W/S GLASS TYPE-TINTED (W/ S/BAND)
8612A1 MLD`G-WINDSHIELD - BLACK
8631A5 A` TYPE - BODY COLOR+CR COAT`G
863AAP CAR NAME - SOLARIS
863CA1 GRADE - GL
8641A1 TOWING HOOK
8642A1 TIE DOWN HOOK(LASHING)
8643A1 SHIPPING HOOK
8651B1 TYPE - 2.5 MILE
8652B1 COLOR - BODY COLOR
8681A1 MUD GUARD-FR
8682A1 MUD GUARD-RR
8712B4 BACK LITE GLASS TYPE -TINTED(W/ HEATED)
871BA1 RR HEATED W/ TIMER
8722A3 H.M.S.L - RR P/TRAY
8731B1 MLD`G - BODY COLOR
8765A1 COLOR - BLACK
8811C1 CLOTH - CLOTH
8821A1 HEAD REST - UP/DOWN
8823A1 SLIDING
8824A2 DOUBLE RECLIN`G
8825A4 ADJUSTER - PUMP`G DEVICE
8854A1 HEAD REST - UP/DOWN
885DA1 SLIDING
885EA2 DOUBLE RECLIN`G
886BA1 SEAT BACK - SEAT BACK POCKET
8881B1 DRIVER`S SIDE - ELR
8884D1 PASSENGER`S SIDE - ELR
8885A2 RETRACTOR PRETENSIONER - ELECTRICAL TYPE
888AA2 PRE TENSIONER - ELECTRICAL TYPE
888DA1 SEAT BELT REMINDER
888KA2 S/BELT ANCHOR - ADJUSTABLE
888RA2 S/BELT ANCHOR - ADJUSTABLE
8913A1 LH
8914A1 RH
892DA1 HOLDER - UPR ANCHOR
892GA1 LWR ANCHOR
8981A4 SIDE - ELR
8982A4 CTR - ELR
9211E3 MFR - CLEAR
9213A2 DAYTIME RUNN`G LIGHT - EUROPE TYPE
921BA1 LEVELING DEVICE - MANUAL
9222A1 RR - CONVENTIONAL
9231B1 INTEGRATED - CLEAR LENS
9232A1 CONVENTIONAL - CLEAR LENS (ON FENDER)
9241A1 CLEAR
9282A2 FR - W/0 SUNGLASS
9287A1 LUGGAGE LAMP
928FA1 CTR - GLOW LAMP
928WA1 BULB TYPE - 1 BULB
9401C1 CLUSTER TYPE - CONVENTIONAL
9402A1 SPEEDOMETER
940AA3 TRIP ODOMETER - LCD
940BA1 TACHOMETER
940CA1 FUEL
940DA1 WATER TEMP.
940EA1 LCD ODO/TRIP METER
9451A1 TYPE - DIGITAL
94C1A1 A/T POSITION INDICATOR
94C6A1 DIRECTION INDICATOR
94C7A1 OIL PRESSURE
94C8A1 BRAKE OIL
94C9A1 PARK`G BRAKE
94D0A1 DR AJAR - DR AJAR
94D1A1 BATTERY CHARGE
94D2A1 HIGH BEAM
94D4A1 LOW FUEL
94D7A1 TRUNK LID(T/GATE) OPEN
94D9A1 CHECK ENGINE
94E3A1 SEAT BELT
94E5A1 A.B.S
94E6A1 A/BAG
94F1A1 A/T `OD`POSITION INDICATOR
94G0A1 WASHER FLUID WARN`G LAMP
94G4A1 FOG LAMP (FR)
94H6A1 IMMOBILIZER
94M0A1 SPEEDOMETER TYPE - KMPH
94N0A1 TEMPERATURE UNIT - C
94X2A1 ECO INDICATOR
9542A1 IMMOBILIZER
9611A2 BLANK`G COVER - GERMANY TYPE
9614A2 COMPONENT 1 DIN - W/ TRAY
9621G1 ANTENNA TELESCOPIC - ANTENNA ROOF TYPE
963CA1 SPEAKER LOCATION FR DR - GENERAL
963ZA1 SPEAKER LOCATION RR DR LOW-GENERAL
965QA1 O/SIDE TEMPERATURE DISPLAY
9661A1 HORN - SINGLE
9711A2 BLOWER - 4 SPEED FAN
9721A2 CABLE TYPE - ROTARY TYPE
9741A1 RR HEATING DUCTS - 2ND SEAT
9811A2 FR WIPER - INTERMITTENT(VARIABLE)
9819A1 BLADE TYPE - CONVENTIONAL
981AA1 FR WIPER-2 SPEED
9852A1 FUNCTION - WASHER FLUID LEVEL SENSOR
WT  2
5692A3 PASSENGER SIDE - DEPOWERED
569BD4 PASS`S - D LANGUAGE
5812A7 RR BRAKE - DISC-14 INCH
5891A2 ABS (ANTI LOCK BRK SYS)
5896A1 ESS (EMERGENCY STOP SIGNAL)
8233B1 CENTER TRIM - CLOTH(A TYPE)
8341A2 POWER WINDOW(FR+RR)
86A1A1 W/ WIPER DEICER
8762C4 PASS`S SIDE - ELECTRIC HTD-CONV
8763C4 DRIVER`S SIDE - ELECTRIC HTD-CONV
8838A1 SEAT WARMER(HEATER)
8873A1 SEAT WARMER
8912D1 6:4 SPLIT BACK FOLD`G - BACK
9761A1 FR COOLER - MANUAL A/CON
C40 RUSSIA[/spoiler]
Спасибо огромное!
Сочи
Пробейте пожалуйста полные данные VIN Z94CT41DACR098015 заранее благодарен.
GELO:
Shadowru, пост 283(на заводе) всетаки поменяли буквенный код,(десятый символ),значит всетаки пост 265 ошибка или опечатка!!!
Сочи
Огромное спасибо ,сегодня ровно 6 месяцев ожидания узнал вин и решил сразу пробить день рождения своего Солика ,обещают к концу месяца привести .
Здравствуйте, пробейте, пожалуйста, данные по VIN Z94CU41DBBR094971, заранее спасибо.
zibert:
Моя машинка в посте 265
Дата схода с конвеера 10.01.2012 это точно
Но цена которую я уже заплатил на днях осталась старая, она указана заводом
дилер сам был озадачен, чевото даже выесняли, хотели поднять
Незнаю работал завод в новогодние или нет, может ее начали собирать еще в 2011
Редактировалось: 1 раз (Последний: 21 января 2012 в 01:04)
GeoDim, каждая 10 буква  означает год выпуска авто в VIN ,А-0,В-1,С-2 и.т.д,соответственно В- 2011,а VIN ни куда не денится поэтому неможет машинка быть 12 года,а при продаже очень будет обидно доказывать что она моложе на год !!!!
kantri:
zibert:
Жду ПТС, думаю там будет указан 2012
а если и декабрь 2011, тоже небеда
Редактировалось: 1 раз (Последний: 21 января 2012 в 17:24)
Екатеринбург
Спасибо за ДР, а можно узнать всю информацию по VIN Z94CT41DABR093285
Здравствуйте, пробейте, пожалуйста, данные по VIN Z94CU41CABR093998, заранее спасибо.
Уфа
Здравствуйте, можно узнать всю доступную информацию по VIN Z94CU41DABR094931?
alex79:
Если нужна полная расшифровка, зачем сначала просить только дату?
maryan_amk:
vdimmaxx:
Уфа
Спасибо большое!
Здравствуйте, пробейте пожалуйста Z94CT41CABR067840
Здравствуйте, пробейте пожалуйста Z94CU41DBCR098472
ЗАРАНЕЕ СПАСИБО
Редактировалось: 1 раз (Последний: 24 января 2012 в 20:28)
а как узнать VIN ?
